Thanks
Cole
It will defrost, and the air does move position to position.kompressorgolf wrote:could also be stuck open thermostat, although it would get pretty warm eventually. does it have any trouble when you try to switch the air from defrost to the floor? i.e. doesnt blow to the floor just defrost regardless of direction switch>?
Manual controls if that helps.MikeWire wrote:Cole do you have climatronic or manual controls? Trevor is right if you have climatronic, but if you have manual controls they are old school cable IIRC.
Sounds about right with the water pump but wouldn't I have other issues overheating etc.?MT-Getto wrote:When I replaced the water pump and changed the coolant on my 8v, the heater went from barely blowing warm to almost too hot. Could also be a vacuum issue with heater controls (consult uncle bently).
Is this located inside the cabin or in the engine bay?MikeWire wrote:Sounds like your heat/cold blend flap is not working correctly and/or is stuck on cold. If you aren't overheating then it's not your thermo or your pump.
