drunken 67 fueler
Re: drunken 67 fueler
So, I was doing some reading since I am going to turbocharge my dune buggy too, and came across this and wasn't sure if you knew...
http://www.smbaker.com/rail/monsterturbovw.html
Word to the wise: There are two different types of seals in turbochargers: dynamic (aka piston) and carbon (aka positive). The carbon seal is suitable for either blow-through or draw-through applications. Dynamic seals are suitable for blow-through only! I repeat, you cannot use a dynamic seal on a draw-through turbo system. This is important. Ideally, you would select a turbocharger that came with a carbon seal already in it, and save youself a lot of headaches later. Unfortunately, carbon seal turbos are a rarity, because the newer dynamic seal is more efficient, and well suitable to the fuel injected engines that are used these days. So, the moral of the story is if you want a draw-through setup, either a) find a turbo with a carbon seal, or b) rebuild your turbo and convert it to carbon seal.
choptopvolksrod
Post by choptopvolksrod »
im sure my chinese 150$ turbo is a dynamic seal unit but i was thinking about getting it rebuilt with good bearings and carbon seal to make it more reliable, but the turbo is working fine for now and the seals arent leaking and its not like the car gets a lot of miles put on it. it idles for 5 minutes then gets ran for about a minute, i would like to buy a garret t3 t4 hybrid with the carbon seal already installed but i dont have the 700 for one so ill probably just dump 250 into my cheap one and never worry about it again.
choptopvolksrod
Looks great, very nostalgic! straight out of the sixties look to it.
:thumbsup: Nice!
hats a good pic of you an ther car! makes you look even taller lol. i like the rat rod wheels on there!
HOTRODKID91
Vehicles: 1963 VW Bug,1963 Ford Galaxie,2003 F-150
Post by HOTRODKID91 »
ehhhhh dont say rrrraaaaa rrrrraaaaaaaa rrraaaaaa ttttttttt well you get what ime saying here some pics i got from the other night
cool pics, whats going on in the last one?
choptopvolksrod
we are swapping to the toe tires to get the hell out of there before the fuzz gets there and before we get carried away by mosquitoes
i think with the mosquities i would have left them on an raced to town lol. see if the trucks keep up lol
