Cole's Cabby
paintballguy424
69 Beetle
Re: Cole's Cabby
Post by paintballguy424 »
Changing the valve cover gasket out today I have a brilliant idea to paint the valve cover red metallic to match the interior. Spray it and it dries pink, just what I need is a tuna basket with a pink valve cover. So I stripped it again and painted it flat black lesson learned.
1969 Beetle
Re: Cole's Cabby
You could go purple. Lol
paintballguy424
69 Beetle
Re: Cole's Cabby
I think that would be too much purple engine pieces for laurel.
1969 Beetle
Re: Cole's Cabby
Not no more it's all you. Lol
paintballguy424
69 Beetle
Re: Cole's Cabby
So I was bolting up the valve cover and noticed this tangling. Controls the fan previous owner couldn't get fan to run (probably the culprit) where does this bolt up to? Onto the valve cover?
EDIT:
This is the after-run coolant fan switch and it mounts between cylinder 2 and 3 on the backside of the valve cover. I tested mine according to Bentley and have to order a new one online, this would cause the radiator fan not to run or run constantly when the ignition is on like the previous owner explained.
Last edited by paintballguy424 on Feb Fri 08, 2013 8:12 pm, edited 1 time in total.
1969 Beetle
Re: Cole's Cabby
Don't they typically go in the radiator?
Re: Cole's Cabby
Or is that an oil pressure unit?
paintballguy424
69 Beetle
Re: Cole's Cabby
90 and up Cabbys (at least) have this after run switch which turns the fan on if the engine is hot and off. The other fan switch (two or three terminal) is on the radiator itself like a usual vehicle. You touch the wire terminal end onto a grounding piece (valve cover etc) and the fan turns on.
1969 Beetle
paintballguy424
69 Beetle
Re: Cole's Cabby
1969 Beetle
paintballguy424
69 Beetle
Re: Cole's Cabby
Stupid Double post
Last edited by paintballguy424 on Apr Sun 07, 2013 9:12 pm, edited 1 time in total.
1969 Beetle
