EPC LIGHT
From the TurboXS website:
Racing Bypass Valve Type 25 (RBV-25) US$169.00
The Racing Bypass Valve Type 25 was specifically designed to replace the 1 inch (25mm) Bosch Bypass Valve used in most Volkswagen and Audi applications. The Bosch valve is prone to failure in stock application and not adequate for holding boost in "chipped" 1.8T equipped vehicles. The RBV-25 spring tension is adjustable, making it ideal for your modified vehicle. This RBV-25, though louder than a stock bypass valve, is not loud compared to an atmosphere BOV.
If you have HKS, then it is probably a SSV, witch IIRC, is amospheric. I am surprised the car is even driveable, but anything is possible. I ma sure some kid wanted the loudest BOV he could get, and well, he got it.
Mike was correct with the TXS RBV-25. Specifically designed for the VAG 1.8T motors. Retail on it is $169.00, BSVW members get 10% back, wich brings it to $152.00. I Just checked the stockroom and i am currently out of them, but it only takes me a couple of days to get them in from TurboXS. I can be reached at my shop at 406-829-3830, as for Aeron. Later guys!
:thumbsup: Aeron. You are the man, dog! CBR I haven't met you yet, but if you want help with installation and clearing your codes get in touch with me through the email or PM function on the forums.
CBCGSXR1000
Vehicles: 2
Post by CBCGSXR1000 »
Aeron i couldnt get ahold of u today.would like u to order the TXS RBV-25 for me. i also need hose adapor .my name is Chris #4066728860 please call me so i can get those befor show on 11th car wont make it up there other wise.ill call u tomarow if dont call me first. ill give u my card number if that will mark it faster.if not its all good got lots to do. peace out :twisted:
CHRIS
YOur RBV-25 is ordered and on it's little way to your house directly. Let me know if you (or anybody else)needs anything. I have lots of outlets for VW/Audi parts.
Rennwagen1 wrote:YOur RBV-25 is ordered and on it's little way to your house directly. Let me know if you (or anybody else)needs anything. I have lots of outlets for VW/Audi parts.
I need some headlight fluid, new muffler bearings, +2 cylinder bolt on kit, and warp drive...
But seriously, what can you do me for on a CAI? One that goes where the carbon canister would be. :unibrow:
Who makes it? YOu are going to have to be a bit more specific than that....
However I do have a special on cylinder bolt on kits right now, PM for details....... :rolleyes:
CBCGSXR1000
Vehicles: 2
Thanks for rbv.I have a extra new vibrant preformance blue aluminum tower strut brace $65 if u know anyone lookin.Fit golf/jetta. :nod:
CHRIS
CBCGSXR1000
Vehicles: 2
new code
Anyone know what pedal postion sencer B is? Code 0221 cant find in chiltons.Might also be tripin ECP light,treaction contorl light,and check engin.All lights come at same time. :confused:
CHRIS
P0221 is a throttle body valve body code. The sensor measures the angle of the valve and the 0221 states "Implausible signal". so, It's either unplugged, dirty, or it needs to be adapted to the ECU. Did you do something recently to make it throw the code? :confused:
CBCGSXR1000
Vehicles: 2
Didnt do anything new was coming up but not all the time.Dana motors cleard it sed it was BOV that caused it but its not. Thanks ill get it checked out asap. If u want to check it out let me know anything will help.
CHRIS
