Brake/Clutch fluid flush
MK 4 GTI
Post by MK 4 GTI »
Its best with ABS cars to use the reccomended brake fluid.
2000 MK 4 GTI 1.8t
1994 Ford F-150 4X4
MK 4 GTI
Post by MK 4 GTI »
The enemy of brake fluid is moisture. We have a meter at my shop that has green, yellow, red light to indicate the percentage of moisture.
Yellow = 2%
Red = 3%
Flush is needed at next brake job at 2%.
flush is needed now at 3%
I will ask where the meter came from. It uses 2 electrodes tho measure the conductivity of the fluid.
2000 MK 4 GTI 1.8t
1994 Ford F-150 4X4
thetwodubheads
Vehicles: 2012 Golf TDI, 2010 Ram 2500 Cummins
Post by thetwodubheads »
Not sure completely, but you may want to research the super blue fluid a little. I have heard from some techs that they insist that the blue dye leads to premature seal wear in the clutch cylinders.
Locked
