They also work awesome for removing sap.
ValveFloat wrote:
Rennwagen1 wrote:...Re-painted the bumpers...
:laughing: That's funny, that was a yearly thing for my Rabbit when I had it.
Yup. I finally got to the point that I don't even remove them anymore, I just pop out the rub strip and mask off the bumper ends and throw some cardboard between the bumper and car and go to town with the Krylon!!
Over the weekend I finished pulling the tranny and installed the new clutch and flywheel, then put it back together. I also pulled the control arms and I'll probably take them to a machine shop to get the bushings popped out and the new ones pressed in.
Now, the ball joints...anyone have a trick for getting them out? They aren't budging even with a tie rod tool. Soaking in tri flow lube to help loosen them up right now - any tips?
MikeWire wrote:Over the weekend I finished pulling the tranny and installed the new clutch and flywheel, then put it back together. I also pulled the control arms and I'll probably take them to a machine shop to get the bushings popped out and the new ones pressed in.
Put some heat to it.. And use a big hammer.
S406
Post by S406 »
Im gonna let my car sit in the sun and get some color.
Audi 9-23-2010
G60pig wrote:Im gonna let my car sit in the sun and get some color.
:banghead:
vrtpassat
Post by vrtpassat »
is that how you make paint shine like glass
Werd - thanks Spence I let them soak in tri flow and then torched them and I was able to drop them out. Control arms with R32 bushings, new ball joints, and a new carbon cabin filter go in tonight! If I have enough time I will flush the brake lines and clutch with super blue DOT4 and try out the new stage 1 clutch.
joeleoso
Post by joeleoso »
Saved it from over a foot of snow. Sorry I should have gotten before and after pics.
2001 Jetta 1.8t | Revo Stg. 1 | Forge 007 DV
Vacuumed it.
