In the past few weeks I've been able to get a few things worked on. First thing I wanted to do was get the interior of the front doors installed and sealed up. Over the summer I pulled the locks and door assemblies out and "hot tanked" them in an old crock pot with some detergent to degrease and clean them up. Worked great, and I can lock and unlock the doors with ease
So the first step was to install new vapor barrier. Following
Amskeptic's Samba thread I made my own.
I picked this up at my local Lowes:
Used my existing door panel and traced out a panel, then cut a piece and made the little inside flap.
After I masked off the door, I used some regular spray adhesive I picked up (don't remember where, I've had it for a while) and used it to spray the door and get tacky:
I cut slits for the door handle and the deluxe vent, then I was able to put the panel back on:
And the drivers side:
One day I'll replace the fiber board with ABS panels, but for now I kind of like the "rustic" look
Thank you Amskeptic (Colin) for making the instructions easy to follow along with.
Next was to replace the nylon slider on the side door - pretty straight forward, pull the side cover, unbolt the old one, bolt the new one on. Comparing new to old:
Next...my shifting was kind of sloppy and it was hard to tell when I was in gear or in N. So some parts were ordered - New bushings and a shift coupler:
Under the bus I found the original coupler and front shift linkage:
I pulled the shifter out, along with the linkage and cleaned them up, replaced the front bushing.
But I hit a stopping point when I got to the front and rear bushings on the rear linkage. The rear can only be accessed with the transmission out, and the front could not be slid far enough forward to access and replace it. One unique thing on the '72 is that there is an extra linkage on the rear half the linkage. I maybe could have removed it, then slid it forward to access the front bushing, but I thought about that
after I got it back together. So, maybe another time...I need new linkage boots anyhow.
Next thing was to get may brakes working 100%. From what I have deducted, my master cylinder is bad, so I ordered a new one.
So, I pulled the old one and removed the reservoir and brake switches, cleaned them up and installed them on the new master.
Old and dirty:
Clean and new:
I have it bolted up and everything connected, I just need to go out and get fluid in and bleed them. Hopefully it will stop on a dime.
