So I drove by the Aleworks, but didn't see the coffee shop - can you guys tell me if it's attached to the place or where it is?ValveFloat wrote:Yes, coffee shop next to AleWorks on East main.
GTG rescheduled to Saturday Feb 3!!!!
Hi guys -
It was great to meet those that were there - Wade, Joe and Brandon. All you guys are very cool and I hope to make it up to Bozo more often for the weekly meet. Oh, yeah and you all have nice rides as well.
Wade, as promised here is your VAG-COM scan:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 021 906 018 M
Component and/or Version: MOTRONIC ME7.1 G V04
Software Coding: 00031
Work Shop Code: WSC 01317
4 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
Control Module Part Number: 1J0 907 379 R
Component and/or Version: ASR 20 IE CAN 0001
Software Coding: 13204
2 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-00 - -
16-10 - Signal Outside Specifications - Intermittent
Full Scan - (after clearing the 01 address engine module codes)
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 021 906 018 M
Component: MOTRONIC ME7.1 G V04
Coding: 00031
Shop #: WSC 01317
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 R
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 01317
1 Fault Found:
35-00 - -
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 B
Component: CLIMATRONIC V 1.0.0
Coding: 01000
Shop #: WSC 01317
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 920 D
Component: A4-KOMBIINSTR. VDO V16
Coding: 05262
Shop #: WSC 30011
IMMO-IDENTNR: VWZ7Z0X1714805
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AJ
Component: 62 Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 01317
End -------------------------------------------------------
Damn that drivers ABS sensor - hope thats all it is and it not the controller...and now I understand your sig.
Until the next meeting or the spring GTG in Missoula!
4 Faults Found:
P1137 - 35-00 - -
P0134 - 35-00 - -
2 Faults Found:
35-00 - -
Coding: 00031
Shop #: WSC 01317
Coding: 13204
Shop #: WSC 01317
1 Fault Found:
35-00 - -
Coding: 01000
Shop #: WSC 01317
Coding: 05262
Shop #: WSC 30011
Coding: 00006
Shop #: WSC 01317
Coding: 00256
Shop #: WSC 01317
- ValveFloat
- Vehicles: 1991 911
