S4 KO4 tubo an some
vegas2017
Vehicles: 01 s4
'03 RS 6
Re: S4 KO4 tubo an some
Post by vegas2017 »
so its finally running...fugured out that the fuel pump needed replacing so i upgraded....now just have to figure out whats wrong with the tranny...goes into 1,3,5 but not 2,4,6....thinking adjustment? either way taking it to VW...hopefully driving this weekend..if so i will definitely put up some pics....
2003 RS 6
2011 Ford f-150 ecoboost
Did you try adjusting you shifter, it's a pretty simple ordeal?
vegas2017
Vehicles: 01 s4
'03 RS 6
Post by vegas2017 »
ya tried that but still nothing..i figure maybe an hour or two at the dealership....i just wanna drive the thing its been a month and i am itching bad....
2003 RS 6
yaaaa ITCHING BAD is a under statement lol. when that thing started up ohhhhhh boy you should have seen your face lol.
That burning sensation in your loins is called Stg III. :twisted:
vegas2017
Vehicles: 01 s4
'03 RS 6
Re: S4 KO4 turbo an some
Post by vegas2017 »
I LOVE IT!!!! i really hope that VW can fix it fast!!!
2003 RS 6
vegas2017
Vehicles: 01 s4
'03 RS 6
Post by vegas2017 »
ITS FINALLY DONE AND RUNNING!!!!! im getting this weird whistle when im at WOT. and it kinda bogs down like its trying to slow down. it only started after the revo flash...not that the flash is bad....i think it may be faulty DV's. they are just the uprated ones out of the 225 TT. better than stock but still plastic. think i may get the much better Forge DV's and see what happens. other than that the thing runs like a raped ape and its not even full stg III yet!!! if anyone has any other ideas what it might be pleeeeeeease let me know
2003 RS 6
Well you probably are way overboosting those DVs. since the S4 was 250 stock, and those DVs were for a 225, and now you are boosting way more, what do you expext?! I had a buddy that was running 911 turbo DVs, which are the same externally, so they bolt right in, but are set up for high german boost!! YOu might do some research into that.......
vegas2017
Vehicles: 01 s4
'03 RS 6
Post by vegas2017 »
well i just got the 034 Dv's and i put them in and took it for a run. the noise is still there but not as bad and when it starts to go away it sounds like one off the cartoon style BOV's and doesnt bog down as much. you think if i scheduled some time with you, could you look at it on a sat? i might just need to have you turn down the boost :crybaby: Also could you get me a podi for a 2001 S4. just let me know when it comes in and ill make the trip.
2003 RS 6
BOOST DOWN BAD.... :crybaby: :crybaby: ......
