SweaterVest wrote:What a tease. I wanna see some numbers!! I've always wanted to put my VR on one.
I couldn't get the files to load on my machine for a good image
See below.
SweaterVest wrote:Also what happened to your D90s?
D90s are safe
Car in a nutshell cause were at page 27:
91 Jetta GLI 16V Recaro Wolfsburg Edition
H&R Cup Kit ~1.5" drop.
H&R Rear Sway
OE ABS brakes without vacuum assist
ECS Geomet slotted rotors with Hawk pads
Stainless Lines
Poly bushings
2003 1.8T 180hp AWP swap, drive by wire - 90K on install, 100k now
O2A trans with hydraulic clutch
Lightened G60 flywheel with VR6 clutch
MTGetto-Engineered eBay front mount bar and plate intercooler and tubing
Silicone inlet pipe
Forge 007 Diverter
O'reilly hot air cone filter
TechTonics downpipe, hiflow TTcat, and borla catback
Stock K03s turbo
Stock coil packs and plugs
42dd CatchCan
Optima Redtop
Deleted SAI and excessive hose mess under intake manifold
TownPump Gas
This not super easy to read but I'll get a better pic up and a video.
Bone Stock ECU at 12ish lbs boost
Dark Red - HP - 197 @ 5820rpm
Light Red - Torque - 192 @ 3460rpm
Unitronic Stage II Tune - 19lbs boost
Dark Blue - HP - 198 @ 5760
Light Blue - Torque - 229 @ 3760
Im not impressed with this tune and feel like I wasted a lot of time and money with Uni. The tune is supposed to be closer to 230hp and 275ft/lbs. It's been a couple years now but I'm going to reach out to them again now that I have better data. Never liked how it drives on it.
