I just can't win, Gonzo Tuning?
SpoolinDub
Vehicles: 2003 GTI, 1999 Jetta Wolfsburg
Re: I just can't win, Gonzo Tuning?
Post by SpoolinDub »
Ross-tech VCDS on the way. Done screwing around. Gotta get to the root of this evil.
:thumbsup:
You will not regret the investment :)
SpoolinDub
Alright so I finally got it today and plugged it in. Scanned the car and here is what I came up with:
VCDS Version: Release 11.11.3
Data version: 20120401
Friday,08,June,2012,09:25:50:15012
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWDE61J534026142 Mileage: 135080km/83934miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 LP
Component: 1.8T S2V1.9c G 0001
Coding: 07500
Shop #: WSC 12853
VCID: 77F3EC4155D6651
9BWDE61J534026142 VWZ7Z0B5804511
4 Faults Found:
16618 - Boost Pressure Regulation
P0234 - 35-00 - Limit Exceeded (Overboost Condition)
17743 - Engine Torque Monitor 2
P1335 - 35-10 - Control Limit Exceeded - Intermittent
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-10 - Mechanical Malfunction - Intermittent
17956 - Boost Pressure Regulation Valve (N75)
P1548 - 35-10 - Open Circuit - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001 785 00200
VCID: 34691B4D54204E9
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0001
Coding: 12344
Shop #: WSC 00001
VCID: 2753FC01C5F6351
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07232
Shop #: WSC 19400
VCID: 2F631421ED066D1
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00001
VCID: F0E1575DB0B8B29
2 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8B Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00001
VCID: 37732C411556A51
Subsystem 1 - Part No: 1C1959801A
Component: 8B Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 8B Tõrsteuer.BF KLO 0002
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
End ---------------------------------------------------------------------
I did a TB alignment for the hell of it and nothing still.
Clear ALL the codes (copy to notepad first) then scan it again. Post the reamining codes. All that matters is the engine module codes.
Well it looks like you have some other stuff that needs fixing as well. e you deleted anything from the car? Looks like you have N75/N249 and coolant temp sensors on the fritz at least.....
Edit: ^what mike said, I forgot some of those could be old::::
SpoolinDub
Round 2, after clear:
Friday,08,June,2012,10:06:10:15012
76
Coding: 07500
Shop #: WSC 12853
No fault code found.
Coding: 0019970
Coding: 12344
Shop #: WSC 00001
Coding: 07232
Shop #: WSC 19400
1 Fault Found:
01304 - Radio
Coding: 00006
Shop #: WSC 00001
1 Fault Found:
01304 - Radio
Coding: 00064
Shop #: WSC 00001
To clarify, you'll need to drive it after you clear the codes...then scan it and post the relevant codes. We only need to see the codes listed under "Address 01: Engine Labels:"
If you were in limp mode due to that overboost code, you should be back to normal.
SpoolinDub
VIN: 9BWDE61J534026142 Mileage: 135090km/83941miles
Coding: 07500
Shop #: WSC 12853
1 Fault Found:
Only boosting to 4-5psi
Limp mode?
Yes, definitely overboost. I'm assuming you have a boost gauge? When you drove it, what did the PSI peak at?
SpoolinDub
Yeah I do have a boost gauge. Only going to 5 at peak...
