Automatic To Manual Transmission swap project.
In true Vortecks fashion I would say...SEARCH SEARCH SEARCHRoadhog wrote:link?wyodub wrote:lookin good man. i'm nuts deep in my corrado too. bent all 12 valves. my project post is on vortex. i'll link it or post it here tomorrowish.
and how the hell did you do that. O_O
LOL fu<kers! N00b!
Cant search when I don't know his vortex username.MikeWire wrote:In true Vortecks fashion I would say...SEARCH SEARCH SEARCHRoadhog wrote:link?wyodub wrote:lookin good man. i'm nuts deep in my corrado too. bent all 12 valves. my project post is on vortex. i'll link it or post it here tomorrowish.
LOL fu<kers! N00b!
I bought it that way. the timing chain was a disaster and looks like timing jumped a few teeth and made quite a mess of valves.
my name there is brownsoda
http://forums.vwvortex.com/zerothread?id=2967800
Corrado - Rabbit - WRX
- In the engine bay...
How is the 5-speed conversion working for you?
Good to see someone elbows deep in a project like that.Roadhog wrote:Tehehe.. IT HAS RUNNETH!!! It runs, drives, all that good shi. Even check engine lights! Its 110% VW.![]()
Check engine light is for the oxygen sensor. I think I just fucked it up putting the water pump in. lol.![]()
But damn, it feels good to hop in and go for a rip around the neighborhood in a Corrado with no exhaust past the cat. Sounds like a stock car.![]()
How do you like the 5-speed?
What code is the 02A you swapped in?
What flywheel and clutch are you running?
Great effort! Hope it is working well for you.
Re: How is the 5-speed conversion working for you?
Its working alright, trans could use a rebuild with a LSD.BigSkyVR6Caddy wrote:Good to see someone elbows deep in a project like that.Roadhog wrote:Tehehe.. IT HAS RUNNETH!!! It runs, drives, all that good shi. Even check engine lights! Its 110% VW.![]()
It was actually no exhaust after the down pipe... Sounded so nice.
Dunno what code it was.. I am running an autotech 13lb flywheel and sachs clutch
Interesting... the reason I asked about the code is that I have a 95 Jetta VR6 w/ 02A that I will be rebuilding this winter and will be installing a Peloquin LSD and changing the ring and pinion to match the close ratio Corrado "CDM" set-up, I will change to the diesle 5th gear for highway use.
Once I have collected all the required parts and removed the tranny, I will be looking for an experienced shop to do the rebuild with LSD.
Any recomendations for local shops for our 02A LSD rebuilds???
