!!Tek's Rocco Progress!!
- Mrbubblehead
- In the passengers seat...
Re: !!Tek's Rocco Progress!!
I was trying to pull the tank out this weekend and got stuck. Some thing is holding it toward the front of the tank. My tank doesn't use the straps to hold it in. It had 4 bolts across the back and 2 on the front, that i could find. Some people say the insulation mats some times stick the two together? Any suggestions?? I cant find what is holding it?
you take off the sending unit wiring?
- Mrbubblehead
Yup. it feels like it is "HOOKED" on something. the front of the tank moves up and down, but it just wont drop????
Hammer?
- Mrbubblehead
A hammer might be the next step. I'mgoing to try to pry first.
- Darkside
- Vehicles: 97' Jetta VR6
sending unit on top disconnected? just a quick thought.
- Mrbubblehead
Yup, Disconnected 2 hoses 1 connector of sending unit. Unbolted fuel pump and all connected. Unbolted filler neck. Unbolted 2 front retaining tabs an 4 rear retaining tabs. That was everything i could find. I'll be back under there this weekend, maybe ill find out what is happening. The front of the tank only moves up and down an inch or so, wont move front to back.??? The back of the tank is all loosey goosey.
- Mrbubblehead
Got the tank situation fixed, new rear motor mount, new pass. half shaft, finished off the 3" intake(barely fit), dash back in. A little more to go, might be able to drive her next week
Drive her to my house and take me for a rideMrbubblehead wrote: might be able to drive her next week
- Mrbubblehead
Got it going today,scrapped the ISV and retuned it. Didn't feel like it was running well and it felt a little under powered. So my buddy Ben and I took it down Cottonwood and back to give the digifant some ejumacation, learned it good. Running much better and more power. Couple more things to do and it will be good to go.
