So I have some sweet 17'' BBS on my 200 that just sits now. So i'm thinking that I will run adapters right now to convert the 4x108 to 5x112 that way I can run the 17'' BBS in the nice months and during the winter but on my speedlines and leave my snow tires on! I need help figuring out the sizing for the adapters I need
So this is the websight I will be getting the adapters from
http://www.motorsport-tech.com/wheel_adapters_pop.html
I don't know exactly what I'm looking for but I will probably want the pressed in studs.
The wheels on the 200 are 17/7.5/et35 I believe and the tires are 225/45/17
The coupe stock tires are 205/60/15 I don't know the exact speedline info if someone else does.
If this info is enough to help someone help me figure out what is exactly needed for this order I would be greatly appreciated
This is the info for the coupe I believe
QUATTRO 85-90 14 X 6 4X108 14mmX1.5b 57.1
THE Coupe Quattro.
Re: THE Coupe Quattro.
Would you be interested in selling your 4x108's when you're all done with this swap?
Well thats the thing, I have the 17" BBS for nice months and when it comes snowy weather, pull the adapters and throw the stock speedlines back on. I'm stuck trying to figure exactly the measurements on the adapters I need but I just hope the 17'' will fit
If you need a set of 5x112 wheels for winter i can probably hook you up
Well I already got some badass snow tires on the speed lines and that's why I would just switch them from nice to bad months
But I need to figure out the adapters right now so I'll have to try and get the sizings right and just hope that the 17"s will fit under the coupe
Cause in order for the hub swap to happen you need urs4 front hubs machines down then the back requires b5 rear hubs and it turns out that the adapters are not possible to fit so looks like I'm just going to have to get some 4x108 wheels and tires if I want something other than the speedlines all year round.
