Page 1 of 2
pisstons or headshim
Posted: Sep Wed 24, 2008 8:46 pm
by vrtpassat
what should i run pisstons or a headshim on the new build up the vrt or should i run bolth any info could be helpfull i allready now witch dose what but need help deciding
Posted: Sep Wed 24, 2008 10:33 pm
by Checkers
Hey John! This forum is for posting help questions about the site just so you know!
BUT you should start a build thread and ask in that!
Good luck man.
Posted: Sep Thu 25, 2008 8:54 am
pistons will always be the best way to go, anyone will tell you that, but ive heard of stock vr6 bottom ends with a head gasket spacer running 15k miles plus! i would definately use arp head studs if you go spacer tho!
Posted: Sep Thu 25, 2008 9:15 am
Moved to the correct forum. I say go pistons - more $ but worth it. How many miles on the motor?
Posted: Sep Thu 25, 2008 12:21 pm
by vrtpassat
allmost 200k but i have herd of vr6 bottem ends holding 350hp with stock internals and the right head shim
Re:
Posted: Nov Tue 18, 2008 5:07 am
by skaterazn
vrtpassat wrote:allmost 200k but i have herd of vr6 bottem ends holding 350hp with stock internals and the right head shim
There are guys running 400+ with a head spacer. That's my goal with the 42# injectors. are you going to be using some sort of software or stand alone?
Re: pisstons or headshim
Posted: Nov Tue 18, 2008 9:02 am
by ValveFloat
vrtpassat wrote:what should i run pisstons or a headshim on the new build up the vrt or should i run bolth
I do believe you will need pistons.
Unless you are going rotory
Posted: Nov Tue 18, 2008 8:15 pm
by vrtpassat
at the moment i am leaning tward cis but kind of spendy
not shure yet it is still a long way from needing the turbo again
Posted: Nov Tue 18, 2008 11:01 pm
I see what you did there, Joe. You are funny.
Posted: Nov Thu 20, 2008 12:02 am
by vrtpassat
i see it now that arin pointed it out that is a prity clever joke very funny hahaha
