Anybody got any tips on how too do this a better way?
How do I go about removing the broken studs & installing new ones?
VR6 guys... I plan on running a techtonics downpipe and exhuast.
Should I just think about an after market exhaust manifold?
x2kompressorgolf wrote:let the penetrant soak in then use a propane torch to heat up the metal around the studs vice grips work but i used a little device meant to get out broken studs if you have trouble still ill borrow it from work, its the cats ass.
