Suspension Questions
Posted: Mar Tue 24, 2009 10:20 pm
OK here are some more dumb questions heading your way, but you guys are used to it by now right?
So I'm looking to lower the wagon approx 1.5" or lower. I have been doing some research about kits. I know coilover kits are ride ajustable but they are also more expensive. So I was thinking a cup kit. Iwas looking on ECS and I came up with this one, H&R Cup Suspension Kit
H&R Spring & H&R Shock Combination, Wagon Only, Perfect combination of handing & ride quality, (Avg lowering 2.0"F & 1.7"R) When lowering the chassis more than 1.4", you must use appropriate sway bar &/or sway bar links, to accommo
H&R Cup Kits are an ideal solution for those that want aggressive looks and impressive handling at an affordable price. H&R's Cup Kits are specially engineered from the ground up with custom-designed springs and shocks that are developed together to work in perfect harmony. Unlike competitors spring and shock kits H&R Cup Kits are not merely a 'matched' spring and shock package but rather a specially engineered 'solution' with springs and shocks being engineered individually in every application. This takes the guess work out of your spring and shock selection and provides you with an application specific precisely calibrated spring and shock set designed to deliver improved handling uncompromised ride comfort and sleek styling in one precision engineered package.
$649.95
Or this one.
H&R Touring Cup Suspension Kit
H&R Spring & H&R Shock Combination, Wagon Only, Perfect combination of handing & ride quality, (Avg lowering 1.5"F & 1.4"R) When lowering the chassis more than 1.4", you must use appropriate sway bar &/or sway bar links, to accommo
$629.95
The two questions I have are, besides the kits what else would I need to get. I know I need front and rear sway bars, but to me it looks like the kit comes with the shocks and springs. That should be all that I need. My last question I have is have any of you heard good or bad things about the cup kits. I think this is the cheapest way to go. I wanted to just get sport springs, but I know that I'd have to get sport struts and sport springs anyways. So why not get a cup kit right?
Thanks for the help.
$649.95
Or this one.
$629.95
