Page 1 of 2
DIY: Audi A4 FMIC install
Posted: Aug Wed 26, 2009 4:56 pm
I picked up a FMIC pretty cheap and threw in on the other night, so I thought I would do a little DIY/writeup.
Tools needed:
Metric socket set w/ various extensions
10mm deep socket
Metric allen wrench w/ ball end
T25 and T45 Torx bits
Cordless drill
2x Hex screws for the boost sensor
2x Nylon lock nuts and bolts to secure the core tabs to the supplied mounting hardware
about 6 hours of time
Here's the kit:
It comes with all the pipes and silicone connectors, wide clamps and the core. I planned on deleting the "cowbell" boost reservoir (explained later) so I picked up a few extra clamps and a 90 degree ABS plastic elbow which are shown below.
Pop the hood.
Remove the belly pan
Remove the snorkel and fog grilles
Here's the collection of parts so far:
Remove the headlights
Remove the 8mm bolt from under the bumper cover, which connects the bumper rebar to the bumper supports. Make sure all the various other bolts are removed from the the fender wells and the bumper should pull forward with some force.
Don't pull too hard because there are the headlight washer lines, homelink harness, fog light harness and in my case I also had fog ballast connectors to disonnect. Pull the washer fluid line off and plug the end of the washer line so you don't lose all your fluid.
You should have a clear shot to your SMIC now
In order to get it out, it's required to pull the radiator core support forward a few inches. So remove the two bolts from the top of the core support/fender, and remove the driver side headlight plate by removing the three screws holding it in place
Two screws on the headlight plate
One screw holding the headlight plate to the fender
Use a T45 bit to unscrew the bumper support bolts about halfway - this will them allow you to pull the core support forward
Pull the core forward towards the front of the car
Now remove all the cold side hoses - the IC upper hose from the throttle body and make sure to remove the short 90 degree IC hose from the bottom of the SMIC. It's a little harder to remove, but just get western with it and it will come off.
Now pull forward on the top of the SMIC, and drop it down towards the ground and remove it
Now you should have an open space where the SMIC once sat
Remove the boost sensor and set it aside
Remove the air dams from around the radiator. There are three: one on the bottom and two on the side - remove the screws and set them aside
Time to move the power steering cooler - it needs to be rotated upward so the FMIC can sit flush.
I ended up having to trim out the part between the lines in the pic below with my dremel. This allowed me to swing the cooler up and out of the way
I secured the cooler with a couple of zip ties and screws the retainer bolt back down, and that cooler isn't going anywhere
Now I could work on removing the hot side IC hoses. Loosen the clamps on the turbo housing and the clamp on the other end, which secures the hose to the stock charge pipe
I chose to remove the "cowbell" boost reservior, so remove the 3 6mm bolts and remove the hose and clamp on the bottom of the DV and pull the entire assembly out
Now we should be done removing parts and can get on to installing the FMIC
Time to install the boost sensor into the upper cold side pipe. I made a gasket from paper gasket material and then used a small amount of silicone sealant between the gasket and the bung
Carefully insert the sensor into the pipe - watch out so that the o-ring on the sensor does not get torn on the sharp edge of the bung. Use the two screws to secure the sensor
Mock up the boost tubes using the silicone hoses and clamps. Be sure to position the clamps so that they don't interfere with any other hoses or wires, and rotate them so it's easy to clamp them snug. I used my cordless drill with some attachments to secure the clamps. I used the torque setting on the drill so that I didn't over-tighten the clamps - but I made sure to get them nice and tight so I don't have any leaks.
On the hot side of the pipes, use the 90 degree fitting on the hose coming out of the upper pipe and attach it to the bottom of the DV, and secure all clamps.
After the pipes are mocked up, install the core following the same guidelines and making sure the pipes don't come into contact with anything.
Make sure to hook up the boost sensor connector, and double check all your clamps and hoses, and you should be able to start the car and listen for leaks (if you have any). Be aware that you may need to clear codes for anything that's not hooked up - i.e. headlights or fog lights etc.
After everything checks out, the bumper can be reinstalled and everything else reconnected in reverse of how you removed it.
I didn't need to trim anything on the bumper, but I did need to trim a tab and the back of the fins on the fog light grills.
Here's the finished product:
Re: FMIC installed
Posted: Aug Wed 26, 2009 5:20 pm
by Darkside
I love the last pic :thumbsup:
Nice work
Re: FMIC installed
Posted: Aug Wed 26, 2009 7:01 pm
by vrtpassat
looks good :thumbsup:
Re: FMIC installed
Posted: Aug Wed 26, 2009 7:46 pm
by sneakyboy1
Even though it's lacking the words at the moment looks like a great write up with great pix!
And I love that last pic too!!! :thumbsup:
Re: FMIC installed
Posted: Aug Wed 26, 2009 9:24 pm
by ValveFloat
That's really cool, but...
I wanna see the DYI for installing those leaf springs in the first pic onto the back of the A4. :D
Have you driven it yet? I'd be curious to know if you notice any difference in boost response.
Re: FMIC installed
Posted: Aug Wed 26, 2009 11:30 pm
Added text - thanks for the replies guys.
:laughing: Joe, I'm in the process of designing and fabbing the subframe for those leafs... :mrgreen:
And yes, I have driven it quite a bit and logged intake temps. I'd say the lag is a little more noticeable, but the boost comes on stronger and smoother. Intake temps are now dropping by about 40 degrees F, which fixed most of the pinging issues I was having. Here's a link to the logs if anyone is interested:
http://bigskyeuro.com/images/gallery/mi ... 11-115.CSV
Re: DIY: Audi A4 FMIC install
Posted: Aug Thu 27, 2009 8:59 am
Wow! Great write up mike, i will be doing this very soon myself. i thought that i was having tuning difficulties, but i was right, and missed a small vacuum leak. :banghead: great pics and instructions. looks like a damn nice kit, great fitment!
Posted: Sep Thu 03, 2009 5:23 pm
by JayRyan
:thumbsup: My pipes come into contact with something and it's obnoxious as hell. Pay attention to that part ;)
And Mike, I really do think your core's larger than mine. That's fine as I feel my lower anyway. Any larger would do me no good :P
Posted: Sep Thu 03, 2009 7:00 pm
Wow Mike! Great Writeup! I bet it would have taken about half the time, had you not taken pics of every screw, hehehe! Anyway, looking at this compared to the Mk4 GTI/Jetta FMIC installs I have done, I never want to do an A4 ever. Nice Job!
Posted: Sep Tue 15, 2009 10:48 am
If anyone is interested, I understand a group buy is coming up on this kit on VWvortex.com. :thumbsup: to the seller of the kit, he has great communication and answers all my emails!
