CIS, A turbo, and a 1600cc engine
- mk2dubber
Alright guys, going to college and having plenty of time to think about my next project i've come up with some plans. I wanna do an Aircooled CIS motor on boost. Im thinkin a mild 15 pounds of boost. I'll be running a 5th injector ran by a pressure switch that is tripped by the turbo pressure to send the extra fuel to richen up the A/F ratio under boost this injector will be mounted in the intake. The only snag i have come across is the Distributor, what distributor can i use for retard under boost, or if i can keep the stock dist with an audi 5000 vaccum retard canister..? Anyways, i have most everything figured out except the dist. And in theory my idea should work.. Now, i just need to source a 1600dp engine and a complete bug minus motor, the CIS system a turbo and a header. Any ideas are appreciated, thanks
- Checkers
Re: CIS, A turbo, and a 1600cc engine
Buy my turbo setup! I'll cut you a deal.
- mk2dubber
We'll see, i might have a k26 already lined up for next to nothing. What do you have?
- Checkers
viewtopic.php?f=59&t=1947mk2dubber wrote:We'll see, i might have a k26 already lined up for next to nothing. What do you have?
- mk2dubber
Mmm.. tempting, we'll see what happens man i gotta graduate here first so if it's around then and i have the cash i'll hit you up. How is being a dad going man? congrats on that by the way! i never really got a chance to say it but i seen the pics on your myspace.
