Amplifier Help!
Posted: Jan Fri 22, 2010 1:14 am
Okay, so I've decided to upgrade my speakers in my car and need some advice from the audiophiles on this forum. I'm in dire need of some opinions on which amplifier I should select. I have a budget set, so I've listed the 3 main amps I'm extremely pulled toward. I know that there are better amps out there, like JL, but I just don't have the budget for it. The speakers I've already intended on using and have purchased are:
Infinity Kappa 462.9cfp 4x6 plate speakers.
http://www.sonicelectronix.com/item_139 ... .9cfp.html
Specs:
RMS: 60W each speaker
MAX: 180W each speaker
Impedance is either 2 or 4 ohms (websites list them differently, so I'm not sure)
Also, I know that all 3 amplifiers are Kenwoods, but I currently use two Kenwood mono blocks for my subs and am now totally biased into using Kenwood again. Besides, I've read some scary reviews on other comparable amps that tends to lead me back to these 3... (P.S. class-D does NOT mean Digital!)
Kenwood KAC-X4R
http://www.sonicelectronix.com/item_120 ... C-X4R.html
Basically, a 4-channel class-D digital amplifier. Getting harder to find, since this was a 2008 model. However, many customers stand by this amp 110%.
Kenwood eXcelon XR-4S
http://www.kenwoodusa.com/Car_Entertain ... iers/XR-4S
http://www.sonicelectronix.com/item_184 ... XR-4S.html
A more compact 4-channel class-D digital amplifier. In the end, it might have to be this amp due to its small size. I don't have much room in my car for bigger amps. However, I have heard (very few) complaints on this amp when attempting to reproduce higher frequencies.
Kenwood eXcelon X600F
http://www.kenwoodusa.com/Car_Entertain ... iers/X600F
http://www.sonicelectronix.com/item_186 ... X600F.html
A 4-channel class-A/B amplifier. A little big, but I'm currently measuring if it will fit in my left hatch pocket.
I read that typically, A/B amps are better for reproducing higher frequencies, but are not nearly as efficient or compact as class D amps, and tend to get hot. However, class D's tend to have difficulties with higher frequencies, but this is supposedly dated information. I read that now many class D amps can be compared to A/B amps in music reproduction quality. But I would tend to believe that that would be in higher quality amps. Remember, the amp would only be used for the Infinity's, so bass would not ever be the issue. I want to choose the best amp for the job, given that I can fit it, and that it doesn't overheat. My current order of preference is:
#1: X600F - Pros: easy to find online for good price, class A/B. Cons: Large, can overheat being A/B, larger current draw
#2: KAC-X4R - Pros: Class D (efficient, inexpensive), Digital amp. Cons: Class D (SQ), large, harder to find online now.
#3: XR-4S - Pros: Compact, Class D (effic., inexp), Digital amp. Cons: Class D (SQ), few customer issues.
I'm not intending for my car to be a comp audio vehicle, but would like to be able to turn up the volume once in a while and not have the speakers beg for more juice. They're currently being powered by the deck (50Wx5, for 5.1 surround), and distort when I start pushing the speakers past 30 (the volume control on the deck ranges from 0 to 40) when the car is turned off, and distort at about 35+ when the car is running. I know one issue I need to perform is the Big 3.
Thanks in advance for your input guys.
Specs:
Kenwood KAC-X4R
