air valve
Posted: Jun Tue 29, 2010 6:03 pm
by GLIjoe
Hey,I have a 1990 gli 16v and was wondering what was the best way to go about eliminating the idle air stabalizer valve? I have a rough idle once the car is warm. I have tried cleaning the valve with carb cleaner but it did not make a differance. The car actually idles better with the wires disconected from the valve . So I was thinking of just pulling it and plugging the holes, then adjusting idle at the throttle body. Besides I would like to get rid of anything I can do without cluddering up the engine bay.
Re: air valve
Posted: Jun Tue 29, 2010 6:42 pm
by MT-Getto
Sounds like you need to stop by and get a scan done :) 406 five seven zero 5672
Re: air valve
Posted: Jun Tue 29, 2010 9:36 pm
by GLIjoe
you flaged me down and scanned it for me once about 4 or 5 month ago and it checked out then, but something may pop up now. I will give you a call, you could stop by the next time your in livingston,or I will drive over to bozeman. thanks
Re: air valve
Posted: Jun Tue 29, 2010 9:43 pm
by Checkers
Talk to Mr. BubbleHead, he just deleted his not that long ago.
Re: air valve
Posted: Jun Wed 30, 2010 12:46 pm
by MT-Getto
He was running a different management.
Re: air valve
Posted: Jun Wed 30, 2010 9:21 pm
by GLIjoe
would it matter what engine management your running? all the air coming through the valve is already meetered so it seems that it wouldnt change anything if it was going through the air valve or the throttlebody.
Re: air valve
Posted: Jul Fri 02, 2010 7:46 am
by Mrbubblehead
As long as the engine management is ok otherwise, tie the wires off to the side some where plug the hole that it went into, adjust idle with the Idle air bypass. You'll most likely have to give it a little gas for a little bit during cold starts but that is about it. These were the instructions I found on the Vortex.
