Radio testing
Posted: Aug Fri 23, 2013 4:46 pm
For those with double-DIN Monsoon radios, here's a way to test your radio's antenna.
With the radio on, press & hold the MIX button 5 seconds or so, until SERVICE TEST MODE shows up in the display. Then press MIX again. This takes you to the antenna test. If it shows up as ANTENNA ON, that means the preamp at the base of the antenna is working (I think).
Pressing MIX again takes you to the next test. At some point there is a signal strength meter; if the line is black, then signal = 100%. You can press the memory presets during this test to see if one station is stronger than another.
Turn the radio off to exit test mode.
