Page 1 of 2
1990 GLI alarm system
Posted: May Fri 16, 2014 6:36 pm
by idubse7en
Just picked up a mark II Jetta. I was able to jump from the battery to the starter and it fired up. However, when I use the key or try to jump the ignition, nothing.
I am wondering if the alarm system is armed or something like that. I have the auto un-lock key and can arm and disarm the system, but the ignition key doesn't engage the starter like it should. I looked at wires, grounds, etc.
What should I look at?
Re: 1990 GLI alarm system
Posted: May Sat 17, 2014 9:48 am
Under the dash for the module? I'd rip the junk out. Do you want to keep it?
Posted: May Sat 17, 2014 10:58 am
by idubse7en
I'd like to keep the alarm system if it's not too much trouble. The auto door locks are nice and I like being able to use the remote, it makes the car special :)
Posted: May Sat 17, 2014 6:57 pm
by idubse7en
I am not a fan of relays or fuse blocks, they are too damn much. The problem I'm having with the car is not the security system. I pulled the starter relay and jumped the terminals and it will start with the key.
Any ideas about why it won't start with the relay in place?
Posted: May Sat 17, 2014 9:35 pm
by itskmill06
Ignition switch?
Sent from my MB865 using Tapatalk
Posted: May Sun 18, 2014 8:21 am
by idubse7en
Switch is okay since it will start with the key. I was thinking its a bad starter relay
Posted: May Mon 19, 2014 6:51 am
by MT-Getto
You identify the alarm module and find a manual? How about a Bentley?
Posted: May Wed 21, 2014 7:18 pm
by idubse7en
This is the circuit, the load relay. The ignition wire comes into the relay and out to the starter. I can jump the relay circuit with a wire, but, with the actual relay it will not start.
Posted: May Fri 23, 2014 5:34 pm
by MT-Getto
You have a seatbelt switch on the starter? Mine required the shoulder belt connected to start the car
Posted: May Mon 26, 2014 8:09 pm
by idubse7en
Ah yes, the shoulder belt., what a fantastic safety feature… Damn.
Well thanks Getto saved me from wasting any more time looking through wires.
