Page 1 of 3
Throttle cut issues, help please.
Posted: Jun Mon 11, 2007 3:40 pm
by Ramrod
I've been researching and thing I've narrowed my throttle cut issue down to a couple things. I'm getting TC in 4th-6th, especially with the chip turned on when I'm calling for high boost. It's happening consistantly when I'm at WOT.
So from my research I either have a boost leak or a bad EGT sensor. I'm going to test for a boost leak this week using a bike pump. I've been unable to locate a compressor with a regulator, so I'm going to try it this way. If anyone has one, hook a brother up.
Both can be diagnosed with a VAGcom. I've got an old version of the software, but no cable. And I'm a bit of noob when it comes to using it, even if I find a cable. Does anyone have any experience with this?
I need to fix this problem to take undue stress of my turbos, but I'm having trouble diagnosing the exact problem.
Posted: Jun Mon 11, 2007 6:25 pm
I have a cable, if you need to borrow it. I can send it out tomorrow if you like. I am not as versed in the biturbo motors, so that is about as much help as I can be right now............but I really like the idea of using a bike pump to check for leaks, that is straight gangsta!
Posted: Jun Tue 12, 2007 12:29 am
I have a compressor with a regulator. If you come down for the run we can test it out (I think you said you were?). I have Vag-Com as well. Or Aeron will hook you up too.
Posted: Jun Tue 12, 2007 8:15 am
by Ramrod
Thanks guys. Last night I tested it using Rob (General Lee Scirocco) compressor. I found one leak, but it was one of the plugs that I installed for doing the pressure test. I have to get a larger hose clamp to fix the issue. Hopefully, I can use Rob's compressor again and give it another shot. The bike pump would work if you had no leaks, but if you do it won't help you find any. I'd like to get the pressure test done and out of the way.
Mike, I am planning on coming for the run this weekend. Do I need to locate which blocks we will need log prior to coming? Thanks for the help, I'm in new terrirtory with this software stuff. Aeron, thanks for the offer, but I'll try Mike's first since I was planning on going to Billings anyway.
Posted: Jun Tue 12, 2007 8:43 am
Ramrod wrote:...Mike, I am planning on coming for the run this weekend. Do I need to locate which blocks we will need log prior to coming? Thanks for the help, I'm in new terrirtory with this software stuff. Aeron, thanks for the offer, but I'll try Mike's first since I was planning on going to Billings anyway.
Yeah, try to find some info if you can, because I have no idea. I use version 3.11, so it's a little older but knowing Ross-Tech they probably haven't changed anything with the block information. Do you have the factory repair manual? I only have it for Jetta/GTI 99-04 - although I have found the codes 'generally' cross over to the Passat and other VAG cars - if you have any that is.
Posted: Jun Tue 12, 2007 10:31 am
by Ramrod
Alright, here's the details.
The EGT blocks are 034/035 or block 112. Both should display the temp in C to determine if they are working properly.
Boost will need to be logged using blocks 114 (Actual boost), and 115 (Spec'd boost). I'm assuming either the software can graph it or the data can be entered in excel.
Here are resources for block identification.
http://s4wiki.com/wiki/VAGCOM
http://www.ross-tech.com/vag-com/m_blocks/
Posted: Jun Tue 12, 2007 10:33 am
by Ramrod
Also read that block 112 should read 1035 with engine off, and 945 with engine running.
http://forums.audiworld.com/s4/msgs/2219339.phtml
Posted: Jun Tue 12, 2007 11:10 am
We should be able to measure and log/graph all of the values. I've used the graph to follow RPM's and it's pretty cool. Your car knows everything you do to it
good or bad
Posted: Jun Tue 12, 2007 11:40 am
by Ramrod
There's a small possibility, given the symptoms, that I have a bad coolant temp sensor. But untill we plug her in and talk to her, there's not much more I can do. Still going to try and complete that pressure test though.
Thanks again Mike.
Posted: Jun Tue 12, 2007 1:06 pm
by ValveFloat
I have a cable also, if you want to borrow it.
I don't have any experience with an S4, but I can help with the basics of the software.
-Joe
