If you have trouble with the VIP code or activation...
Join or login to participate
Go here first and get it: http://forums.bigskyvw.com/viewtopic.php?t=292
If you can't get there, please contact me directly mike@mikewire.com
I have tested the code and it has worked fine for me under multiple test registrations. If I cannot replicate the problem, then I will assume it is operator error - so, the more information on the problem you can give me, the better I may (or may not) be able to replicate the problem, and fix if needed!
One other issue: If you get through the sign up process and your activation email gets deleted by your junk mail filter, please contact me directly mike@mikewire.com.
Thank you all for your cooperation!
Mike
