WTB: SAI for B5 Passat
Posted: Nov Wed 14, 2007 4:29 pm
by rabbitking
i'm lookin for a secondary air pump for a 2004 V6 30v Passat Wagon.. can anybody help?
Posted: Nov Wed 14, 2007 8:05 pm
b5 passat rabbitking????? sorry now if you was lookin for rabbit parts....
Posted: Nov Wed 14, 2007 8:12 pm
My seconday air pump has been out for a couple years now. You learn to live the the CEL. You might try calling Rex in parts at Mountain Imports in Missoula, 721-3395, and tell him Aeron told you to call. He is my go-to guy for parts around these parts.
Oh yeah, I got lot's or rabbit parts also.
Posted: Nov Wed 14, 2007 9:30 pm
Sup Eric, here is your Vag-Com scan:
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 3B0 907 551 DB
Component: 2.8L V6/5V G 0010
Coding: 07751
Shop #: WSC 05311
WVWYH63B94E030571 VWZ7Z0C7587855
2 Faults Found:
17831 - Secondary Air Injection System: Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System: Bank 2: Insufficient Flow
P1411 - 35-00 - -
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 3B0 927 156 BA
Component: AG5 01V 2.8l5V USA 2225
Coding: 01102
Shop #: WSC 19226
1 Fault Found:
17087 - Brake Switch B Circuit Malfunction
P0703 - 35-10 - - - Intermittent
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 04257
Shop #: WSC 05311
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0006
Coding: 17200
Shop #: WSC 05311
4 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
01271 - Positioning Motor for Temperature Flap (V68)
37-10 - Faulty - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
No fault code found.
Address 17 -------------------------------------------------------
Controller: 3B0 920 929 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15235
Shop #: WSC 19226
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
Address 36 -------------------------------------------------------
Controller: 3B1 959 760 E
Component: Sitzverstellung 0301
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
01008 - Note: Emergency OFF Switch is Active!
000 - -
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 C
Component: 81 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
Address 56 -------------------------------------------------------
Controller: 3B7 035 180 G
Component: Radio NP2 0016
Coding: 04031
Shop #: WSC 05311
End -------------------------------------------------------
Posted: Nov Wed 14, 2007 9:32 pm
wow.. Thats alot of codes.
Posted: Nov Wed 14, 2007 9:33 pm
by Ramrod
Your brake switch is thowing a code? Weird
Posted: Nov Wed 14, 2007 9:35 pm
Ramrod wrote:Your brake switch is thowing a code? Weird
Yep - recall. He actually got that done @ Dana, but I don't think they cleared the stored code
Posted: Nov Wed 14, 2007 11:17 pm
I don't know if anyone cares or not, but all the secondary air pump does is feed clean air(not exhaust) into the cat somehow to help it warm up faster or something like that. The only side effects of a bad SAI is possible cat damage over a long period of time and a CEL. I have had a bad pump for like 2+ years and no problems. Excpet the CEL, but it is a Mk3 VR6, so I just find one I can live with and leave it alone. Audis, on the other hand my spontaneoulsy combust.
