The trans seems to leak a bit of oil when sitting so it looks like you have to add a bit ever two weeks or so. I imagine it depends on how it is driven and how long it sits. I called Brax and he has transmissions for $200, $400 and rebuilt for $700 but he also said it is quite common for the seals to go where the axles connect. If it is the seals, I guess they are about $12 bucks plus time. I don't care to play mechanic any more than necessary. I like to clean and polish my car, but I don't want to work on them much.
The front is a bit messed up after an encounter with a deer a year ago. It was partially repaired.
The guy I got it from drove it a 168 miles to get to Bozeman on 4 gallons of gas. Tires are fair and it will need an oil change. At this point, I am trying to avoid putting any cash into it. I am just driving it to see how well it does.
If you have any interest in buying it or trading it for something else that is aircooled or has a big screen or ????? Let me know. All reasonable inquires will be considered.
