Interior Cleaning...
What products do you use?
I am looking to clean my leather and carpet... The carpet has a bunch of stains I would like to get rid of. :D
Ok guys.. Help me clean it please...
well if you went that far, you need two things. You need a prefessional degreaser called Red Hot. You can get it from me, or Unichem in Missoula. Then you need pressure washer with heat. soak it in red hot, and hit it square inch by square inch with that pressure washer, and then let it drain. Works everytime.
Rennwagen1 wrote:well if you went that far, you need two things. You need a prefessional degreaser called Red Hot. You can get it from me, or Unichem in Missoula. Then you need pressure washer with heat. soak it in red hot, and hit it square inch by square inch with that pressure washer, and then let it drain. Works everytime.
How much would it cost for you to do it?
Red Hot works wonders, I used it a lot when I was cleaning cars.
holy ish Aeron kicks ass..
He cleaned my carpet.
WOW!!! :eek:
Impressive!!!!!!!!
How did the black carpet come out?
Aeron, I wish I was closer so you guys could clean my car. I don't trust the shops around here, and my car is filthy. Hopefully the snow will finish melting and dry out so I can clean it.
I am glad that it turned out, Spence. Did it finally dry out?
Locked
