so the water pump on the raddo is leaking ever so slightly. i know what it takes to remove and install one, already did the research on that one. my question is which one of these do you guys think would benefit me in the long run, i don't want to do this again anytime soon.
http://catalog.worldpac.com/ibusiness/J ... Water+Pump
thanks in advance, cody
vr water pump
vr water pump
92 digi 16v jetta
soon to have 88 8v golf
- vrtpassat
Re: vr water pump
the o.e. one
Re: vr water pump
that's what i was thinking, but i didn't know if the metal impeller would be god or not. i guess if it came apart for some reason, the metal one would/ could tear some stuff up. thanks again.
92 digi 16v jetta
Re: vr water pump
Nope. you want the metal one. The plastic ones break very often. Which is the reason the metal one was built to replace the faulty plastic impeller.mk2jetta wrote:that's what i was thinking, but i didn't know if the metal impeller would be god or not. i guess if it came apart for some reason, the metal one would/ could tear some stuff up. thanks again.
Also, its like a 30 minute job max. Remove front and rear engine mount bolts, remove airbox, belt, jack up engine, and unbolt waterpump.
http://www.germanautoparts.com/Volkswag ... ling/163/2
Re: vr water pump
right on thank you. pretty much everyone over on inlandeuros said the metal one too. i just wanted to get some opinions on it.
92 digi 16v jetta
- vrtpassat
Re: vr water pump
its your engine treat it like you would like to be treated metal herts i no i am going to get shit for this on my engine with the turbo but hay i like bing blowed so why not
Re: vr water pump
Yeah, when I redid my pump, the rebuild actually had a metal impeller. And it was a rebuilt OEM pump also, so score!
