CoilPacks Dying at an alarming rate
Dubber
Post by Dubber »
Hello!!
My 1.8t blew another coilpack yesterday. This is my 6th or 7th one..
Anyone have any idea as to what is causing these to blow all of the time??
My mechanic had me put in Autolite plugs last time - I think i am going to go back to pure stock - Or do you think there is a better one to go for?
I do have the car chipped so having a more reliable coilpack is neccessary.
Re: CoilPacks Dying at an alarming rate
I would go back to the factory plugs, and possibly factory coilpacks? They might be more expensive, but if the don't go bad, there you go.
Dubber
Post by Dubber »
Thats what i am thinking - I am tired of this =(
best place to get those products? can you get them?
Make sure to get the revised version of the coilpack if you are not already. OEM are a revision "E" for engine code AWD or a revision "R" if you have engine code AWW or AWP. Like Aeron said change your plugs too, and get NGK coppers, single electrode, stock heat range - they should be like $2.50 EACH. And get a plug gap tool and make sure to check and set the gap before you put them in.
You can get singles or a 4 pack of CP's from ECS tuning.
Dubber
Post by Dubber »
Anywhere in town you know of? its a pain to drive the car like this ...
Coppers? even for the turbo'd car??
Actually after reading some stuff on NGK's site HERE I think you may want to pony up for the cost of some Iridium plugs. It sounds like they have a reduced voltage requirement and more durability and are recommended for turbocharged cars. The coppers do have a copper core but are wrapped in a nickel alloy.
I think the reason your CP's are failing is because of heat caused by increased cylinder pressure and that just works it's way up the like to your CP's. FWIW I could tell you had a failing/misfiring CP because every time you would drive off, your car sounded like a Subaru :)
[quote=dubber]Anywhere in town you know of? its a pain to drive the car like this ...[/quote]
Ya man, just go over to Dana or you could try the BIG Napa on Southgate drive.
Dubber
Post by Dubber »
So i should do Iridium plugs that are OEM replacements, and i need the R revision of the coilpacks?
all able to be bought from napa or dana?
Dunno that dude, you'll need to take charge to make sure you get the right ones. Find your engine code and get the right CP's, then go to Napa and get the Iridiums. Change them out. Profit.
You may try a 1 step colder plug - it will reduce the temps on your CP's and probably help. If you try that just run them for a few hundred miles and see how they are holding up - if they are fouling you should stick with the stock heat range.
Dubber
Post by Dubber »
I called dana - I am looking at 32 a coilpack for the R revision for my car
17 dollars a plug for iridiums.
I am going to pick up some stuff - I know the harness hooking onto the plug is cracked - 50 bucks from ecs should i pick one of those up too?
