car decided it wanted to only intermittenly start last night :banghead: :banghead: :banghead: :banghead:
spent the last two days cutting and buffing then it doesnt want to start. little bastard. i got like 48 hours to figure it out!!!!
and i WILL figure it out :ninja:
We all have faith in you! :thumbsup:
If not ill fix it for you by driving it.
:rolleyes: not if it wont start :thumbsdown: you have problems with differentials i dont need that bad luck :laughing:
found out at lunch it wasnt getting spark fuses were good wires tested good so i need to check hall sensor magnets and sensor alignment as well as the ECU>
fearing a burned coil pack, i removed it and removed the bottom cover, all electronics are dry and look perfect no burn marks melted solder etc. it will be something simple. :thumbsup:
MikeWire wrote:Matt, I need more coffee to answer all those questions. :laughing:
Seriously, can we talk about that on Friday? Or make a new thread in the MKIV category so this threads stays on topic. I would like to see what yours look like, because I think mine looked fine with no soft touch or paint. I tried all kinds of things, and the only thing that looked good was nothing.
Yeah I thought I was getting off topic but I went with it. I am thinking I should have left it alone. too late. I'll show you Friday. Time for an interior swap, :mrgreen: this is why I don't try things I usually wreck them. I just hate the peeling look.
It took till 12:30 last night but i fixed it, the coil pack got some water in in and was corroding to ground :thumbsdown: but for some reason it wasnt blowing the 7.5 amp CP fuse???!!! got it cleaned out fired right up. see you fellas tomorrow :laughing:
kompressorgolf wrote:It took till 12:30 last night but i fixed it, the coil pack got some water in in and was corroding to ground :thumbsdown: but for some reason it wasnt blowing the 7.5 amp CP fuse???!!! got it cleaned out fired right up. see you fellas tomorrow :laughing:
yes, master :ninja:
:laughing:
You have my beer for that generator? :laughing: I have that and a shitload of parts to hand out!
i got some hand-outs too courtesy of Montana Import Group. Hone up on your vw Trivia.
ill wait till you arrive, you know, its your Brand preference :laughing:
Are we having trivia night? I might be able to dig up some SEMA swag also!
if anyone wants to donate any prizes for trivia and hand-outs feel free to bring a little something for it.
