Scanned the Passat
Discussion regarding the software diagnostic solution
Scanned the Passat
Ok, I got my adapter for OBDI cars and hooked it up for a scan:
VAG-COM Version: Release 311.2-N
Chassis Type: 31 - VW Passat B3
Scan: 01,02,03,08,15
Address 02 -------------------------------------------------------
Controller: 095 927 731 BE
Component: DIGIMAT A820
Coding: Diagnose VW
6 Faults Found:
00281 - Vehicle Speed Sensor (G68)
03-10 - No Signal - Intermittent
00293 - Multi-function Switch (F125)
25-10 - Unknown Switch Condition - Intermittent
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
00529 - Engine Speed Signal Missing
35-10 - - - Intermittent
00545 - Engine-Transmission Electrical Connection
31-10 - Open or Short to Ground - Intermittent
00652 - Gear Monitoring
27-10 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
End -------------------------------------------------------
I have my Bentley but I have not gotten out the multimeter yet. I'm a little stumped on "Engine-Transmission Electrical Connection" and
"Gear Monitoring" - maybe a ground has come loose, and a valve body in the tranny is clogged? Any ideas?
