02A and Valver Questions
Does anyone know what needs to be done for exhaust when slappin a PL or 9A into an A1 chassis? I was also wondering what people have done to convert over to the cable-shift/hydro-clutch. Eurospeed has a kit for the clutch pedal and booster bracket, but this would need to be done on the cheap with a b3 donor. Ideas?
Re: 02A and Valver Questions
to make it easiest, get the linkage from a eurovan, and a CRX (honda) clutch cable. thats the easiest way, i will be doing a hydraulic clutch when i swap, but as for how im still unsure. you will have to custom make a drivers tranny mount and a rear tranny mount for it to fit in there.
- Mrbubblehead
- In the passengers seat...
With the 9a you need the PL exhaust manifold from a Rocco, and that is it. simple as that. I dont know much about the cable shift.
- vrtpassat
hay dose that b3 doner have a obd1 vr6 with a dizzy cause if it dose i would really like the wiring harness for mine it is still all chewed up
Tis the 16v, sorry.
