Re: 20VTMK2GLI
That looks like one heck of a job. Good luck.
choptopvolksrod
Re: 20VTMK2GLI
Post by choptopvolksrod »
this swap is so cool they read it in kelvin!
Re: 20VTMK2GLI
Got the gearbox back together. Seems to work okay. I can shift into all gears and everything seems to spin :) I can now do your 5th gear swaps.
Re: 20VTMK2GLI
Nice work!
Re: 20VTMK2GLI
MT-Getto wrote:Got the gearbox back together. Seems to work okay. I can shift into all gears and everything seems to spin :) I can now do your 5th gear swaps.
If you changed gear stacks or cases you will need to set the preload on everything.
Re: 20VTMK2GLI
Where did this guy come from?????? :)
I know that is supposed to be done but I don't have the tools to do this so I'm gonna take my chances. If I grenade the gearbox I'll do it right with the next one and remember I was warned :paranoid:
If anyone is curious, the procedure Spencer speaks of is on pg.14 of this document.:
http://www.vwmotorsport.com/vwtech/gear ... erhaul.pdf
Good stuff on the o2a in there.
Jd3
Silky Johnson
Silky Johnson
Vehicles: emgay4 sixbangr
88 16v prjct bloodysteak
Re: 20VTMK2GLI
Post by Jd3 »
looks like you got it whacked.... but if you need more tranny info ( not spencers friday night dates ) this guy is the vw tranny guru of the universe. Great and informative write ups.
http://brokevw.com/
Re: 20VTMK2GLI
Jd3 wrote:looks like you got it whacked.... but if you need more tranny info ( not spencers friday night dates ) this guy is the vw tranny guru of the universe. Great and informative write ups.
http://brokevw.com/
Love this guy's site. Its mostly for the o2o gearboxes, but wonderful info for the average Joe.
Jd3
Silky Johnson
Silky Johnson
Re: 20VTMK2GLI
Post by Jd3 »
thought i saw that preloading info on 02a at bottom of home page :thumbsup:
Re: 20VTMK2GLI
Progress has slowed down a little. I got the gearbox mess cleaned up so I could keep moving. Holes now cut in the firewall for the master cylinder and the booster bracket is in. I also fabbed up the drive by wire pedal setup :thumbsup:
