Yeah I go tired of using fine grit sandpaper to clean up those terminals
This stuff works magic!
Although it didn't seem to fix my starting issue I thought I had licked. I pulled the battery out, and dropped it on the ground a little too hard, and the fricking bottom corner busted right open, leaking battery acid all over the floor.
Cleaned up, but now I need a new battery. I think that one was shot anyhow, so a trip to Costco tonight and I'll have a new one.
Lately I've also been working on the cluster lights, indicator, and turn switch. I rewired the cluster so all the lights now work and signals flash etc. but I need to add a couple of bulb holders and bulbs that are missing.
My turn switch is busted - it flashes fine but the plastics inside are messed up and broken. So I have a new setup hopefully coming next week and that should take care of that problem.
