2003 Audi A4 Avant - 5 speed manual swap
Some parts coming into my garage soon to transform my Avant from a two pedal to a three pedal. Updates as things progress :thumbsup:
Workflow:
  1. Parts needed:
    1. 01A 5 sp. transmission with B6 tailpiece
    2. Valeo HD clutch and SMFW
    3. Pilot bearing from an Audi 2.8L V6
    4. Manual trans drive shaft
    5. Manual rear diff
    6. Manual pedal cluster w/ clutch switch
    7. Master cylinder
    8. Slave cylinder
    9. Brake res. -> master cylinder soft line
    10. Master cly. -> slave cly. hard line
    11. Manual downpipe
  2. Drop exhaust
  3. Pull trans, rear diff, front axles and drive line
  4. Remove auto pedal cluster
  5. Install pilot bearing
  6. Install clutch
  7. Install shift housing
  8. Install transmission
  9. Install pedal cluster
  10. Wire up clutch switch etc.
  11. Fluid into front diff, trans, center and rear diff
  12. Bleed brakes and clutch
  13. Re-install the driveline and torque to spec
  14. Reprogram ABS, ECU and cluster w/ VCDS
  15. Drive and redjust, etc. as needed
Mikewire's Audi A4 Avant 5 speed swap
Nice your dream is coming true.
Re: Mikewire's Audi A4 Avant 5 speed swap
sweet glad to hear its coming together for you
Also you better get that Caddy in tip top shape. Your going to need a dd when the Audi is down. :laughing:
unless the bus is up an running nicely
Bus is doing great, but neither vehicle is a kid hauler. I'll figure something out before then.
Wait isn't the bus a transporter? Not the safest but was meant to haul people. Lol
Station Wagon, and yeah it transports all right, but at 55 mph. Not the desired speed for daily driving on I-90 right lol?
MikeWire wrote:Station Wagon, and yeah it transports all right, but at 55 mph. Not the desired speed for daily driving on I-90 right lol?
Just try it for a few days. You'll be happier when you get to work, and before you know it you'll be wondering what all the hurry was about. :)
Oh shit!! Fasten your seatbelt, grab a red bull or five, and watch the carnage begin! I am going to upgrade my bandwidth just to deal with the pics......
And Rammy, I heart your philosophy. I kinda feel like that when I drive the Rabbit to work....after my teeth stop vibrating, that is.
Mike, don't you still have the Tahoe AND the Jetta? I mean, she can't drive both to work....
