Digifant mk2, no spark
Re: Digifant mk2, no spark
Can you get an accurate reading from the injector wire with a regular multimeter? Looking for a flicker with an LED test light might be your best bet. One side should be +12 and the other a square wave / pulse from the ecu to ground. Is it possible that your fuel lines are backwards? I do that almost every time. Blue is the return? (like I said, I mess that up). Have you pulled a plug to see if you are getting any fuel? If it is flooding, the CTS can be an issue as can a bad ECU.
idubse7en
Vehicles: Mk2 Gti, B4 Glx
Post by idubse7en »
The injector wire is getting 4 volts on one side and its not flickering on the other side. I checked the injectors for continuity and they are okay. Is their a way to see if my ECU is good without trying another one? Either way I am looking for another ECU if you know where to find one its a digifant II and the part number ends in AT. I see one on ebay for $118 shipped. Why would the ECU fail :confused:
idubse7en
Post by idubse7en »
Its alive! I had the cold start plug and the injector harness plug reversed them and it fired right up. Everything is working good brake peddle is going to the floor almost but still stops fine. And the engine is idling high at about 1400rpm but i haven't reconnected the the idle switch(S***) Im going to go do that now.
Hell yeah!
:thumbsup: :thumbsup: :thumbsup:
Nice
always something simple!
idubse7en
Post by idubse7en »
Yeah :smirk:
:thumbsup:
kompressorgolf wrote:always something simple!
I know!
It just started snowing here in Kali. Im wondering if I should reassemble the heater core back into my car or look for an electric heater for warmth and defrost, I don't want a cheap 12V fan tho I might have to for now, any Ideas? Also the wiper fluid is gone now too but Im going to try to mount it in the trunk and use the existing pluming. Anyone done this? I've seen a couple forums I think.
well there is a heater made by kates thats a 900 watt which is pretty warm. you can go to carquest an get one. line code is HTR the part number is 78037 an i dont know if they have one but i know they can order one for you. thats what i got out of my books to hopefully help.
idubse7en
Post by idubse7en »
padroB5 wrote:well there is a heater made by kates thats a 900 watt which is pretty warm. you can go to carquest an get one. line code is HTR the part number is 78037 an i dont know if they have one but i know they can order one for you. thats what i got out of my books to hopefully help.
Might give it a try with this:
