$900.00 MAKE OFFER Need Gone, buying a more modern awd passat/audi wagon.
95 passat 5 speed wagon. 180k
B3 wheel and glove box swap, neuspeed p-flo, black carpet swap.
brand new windshield. car runs great, always starts ever on the coldest of mornings.
Needs tlc..
driver window regulator, t-stat (included), a front wheel bearing and hub. rear brake discs (bearings included)
front axles (included) needs two front fenders, also eventually will need a clutch, the flywheel/pp got hot (wife) and case hardend itself, now its wearing the clutch faster than it should. still works.
*EDIT, new stuff i remembered
Gas gauge reads only 1/2 after fill up, heated seat no work, pass side rear door handle doesn't work, window on that door no work either. No ac/abs/cruise. El cheapo door handle on drivers door, works but is annoying.
call,text,pm,post questions, whatever works. 4twotwo nine1fifty
Looks the same only dented fender on pass side now and blue painters tape holding up the drivers window.
_________________________
