My 01 Wolfsburg
- paintballguy424
- Vehicles: 2009 Tacoma TRD Off Road
69 Beetle - Location: Laurel, MT
Re: My 01 Wolfsburg
Oh yeah I know i got hit 2 years ago sided with him because he was over fifty and didnt even take a statement from meDarkside wrote:have fun. It was hell for me.
- paintballguy424
Re: My 01 Wolfsburg
Got my car back looks amazing only took two days dropped it off Tuesday morning picked it up Wednesday. American Auto Body overnighted parts in yesterday after they found an extra bracket was broken
- paintballguy424
Re: My 01 Wolfsburg
Door alarm going off randomly. Mike is this the right part?
http://www.ecstuning.com/Volkswagen-Jet ... or/ES3332/
Door latch assembly drivers front door part number 3B1837015AS how terrible is this to put in?
Re: My 01 Wolfsburg
Looks like the correct part in the picture. Just verify the VW part number matches. Its not that fun to replace, and you probably want to order additional door panel clips because they tend to break.
- paintballguy424
Re: My 01 Wolfsburg
Reading this diy
http://www.taligentx.com/passat/mainten ... mechanism/
and this one
http://forums.vwvortex.com/showthread.p ... g-problems!!!-(
This looks like a major pain. I might get it apart and see if I can get away with resoldering it. Looks like the triple square set I bought won't go to waste.
and this one
Re: My 01 Wolfsburg
Yeah its worth a try. Its not fun to get it out but it's worth doing it so everything works correctly. Its just awkward and tough to get your hands in there to disconnect everything.
- Kicking the tires...
- Vehicles: 07 Honda Accord
Re: My 01 Wolfsburg
If it's anything like an 03 Golf, it's a pain in the butt to replace. Everything inside the door must be removed, even the glass and it's frame. Even the door key lock.paintballguy424 wrote:Door alarm going off randomly. Mike is this the right part?
Don't pay for the entire latch though. Just replace the switch. I got one from Radio Shack for $3. It is not an exact replacement, but with 15 minutes of work with a Dremel with a cut-off wheel, I was ready to put the whole assembly back in. It's been working for ~5 months now.
- paintballguy424
Re: My 01 Wolfsburg
This could be a issue here broken throttle body bolt and double gaskets on the intake. Is it come procedure to remove the throttle body when doing the timing belt?
Sent from my iPhone 5 using Tapatalk
- paintballguy424
Re: My 01 Wolfsburg
Didn't have an epc event for a year now it is stuck in it everytime I start the car it is on since last Monday. I did spend a weekend driving dirt roads before this happened. My fear is that a rock kicked up and fried the o2 sensor killing my ECM I haven't inspected the wiring.
What I've done. Battery was replaced this winter don't think that could be it. New plugs, cleaned throttle body, throttle body alignment, inspected wiring from throttle body to ECM couldn't see anything and cleaned maf. Replaced the pedal last year around this time with oem new one.
Obd2 code I get is p2138. Vacuum is all over the place when on interstate holding 70mph vac bounces 5-15 constantly then settles then repeats.
Things I think it could be wiring, throttle body, ECM. What are your guys thoughts?
