damn dude, hopefully everything is alright.
Brandon, have your friend sell that 200 to me...now.
youll know it when you see it, never seen a cleaner one!!
Just saw it!!!!! Headed your way Brandon
I bet Rob's is cleaner..ahaah
Had it completely reassembled. Ran for a few minutes before leaking too. Second time around was much easier, now that stripped fasteners are repaired and knowing how the front is put together.sneakyboy1 wrote:Dude that sucks. Had u gotten it all back together before you discovered it?
Sent from my SCH-I535 using Tapatalk 4
I pulled the alternator out of the way and did the thermostat assembly while I was in there again. It crumbled when I looked at it, and I'm pretty sure the Tstat was sticking open.
Now she's happy as a clam. Ill start a thread when I get some photos soonly.
- Jd3
- Silky Johnson
- Vehicles: emgay4 sixbangr
Great work on both rides trev
If it makes you feel any better, I did the same thing on the first timing belt job on my car. I popped in a crank seal a little cockeyed apparently or too far in and had a nice drip for a couple years until I redid the timing belt when I did the headgasket, among other things.
I put my snowtires on in preparation for snow-magedon! I wish it would dump!
- JayRyan
- Spoolin!
Swapped in the B7, non-peeling cupholder-delicious center console, new Depo housings (right turn signal STILL doesn't work :/), new coolant temp sensor, got the HU DVD bypass fixed, sunroof switch cleaned and my snowblower's running again...the latter Audi relayed because it clears my driveway
Now for new tires. I didn't rotate them enough or swap out at all this year so the fronts are great, backs stink.
Anyone want to buy two good condition Vredestein Wintrac Extremes in 235/45/18?
Sent from my HTC6990LVW using Tapatalk
‘14 Sequoia
'11 Sprinter 170” Diesel 2WD
- JayRyan
- Spoolin!
‘14 Sequoia
- JayRyan
- Spoolin!
Stupid phone app. I'll delete these tomorrow
‘14 Sequoia
