WTB drivers side 020 trans 100mm output flange
Need a drivers side 020 trans output flange in 100mm, the piece the axle bolts to, please let me know if anything! also i have a 90mm 020 trans sitting around that someone can have if they need one.
Re: WTB drivers side 020 trans 100mm output flange
Post by SweaterVest »
I have an 02a flange from a mk3 VR. I have one or two others laying around. Is that the style with the C clip?
02A wont work, it is the press on type with the c clip on the outside
benno3231
Post by benno3231 »
I just happen to have a few of those laying around :) how soon do you need them?
pretty soon, have new c clips and everything, just need that flange and heavy duty spring that sits on the back of it
benno3231
Post by benno3231 »
I got it. Text me and we'll figure out how to get it to you.
Mrbubblehead
Post by Mrbubblehead »
I have a 020 from that 91 gl it's probably a 90mm not sure
benno3231
Post by benno3231 »
020's are pretty random it seems from looking at all the different trans codes. You'd have to measure it
90 and newer should be 100m maybe?
benno3231
Post by benno3231 »
I think you're right. The trans that came in my 91 gl had 100 mm
