New to me Jetta. Got it middle of Feb. 2014 in San Antonio, just under 200k miles.
Current issues:
Airbag light on
Electronic stability? light is on
Random rattle when idling
Off the bat I changed the oil with Mobil 0-40w vw505 spec. Kinda digging the cartridge oil filter, neat-o.
Recently I went digging for the random rattle. Checked the motor/transmission and dogbone/pendulem mount
Look good
Found the flex coupling off the down pipe is wearing out and will need replacing at some point. Had a thought that this may be the rattle, but started the car and pushed the motor forward while running with a jack and rattle did not present.
While I was working down there, I noticed a torn CV boot. Found that replacement boots are 20 per side so I just did remanufactured axles at 50 each. Turns out you need a special tool, 8mm 12point triple square which I couldn't find locally so I ordered a set of those.
While I was waiting for those to show up, I thought I'd check the intake manifold since this is common to clog up with carbon from the EGR.
Oh, looky there what I found.
These are block offs for the EGR at the exhaust manifold and also at the entrance to the EGR cooler. Sweet!
Decided to continue anyways with the dissemble and it looked good, but I touched it up a tiny bit.
I got the car from a dealer and don't have maintinence history on it. I do know it has DieselGeek short shift kit and the DieselGeek heavy duty Panzer skid plate.
Since I don't know the history, I ordered the DieselGeek timing belt kit and the tools to do it. Just waiting to save some more $$$ so that I can get the software to tune it before doing the timing belt change. I suspect given that the car look well maintained that the TB has been done already, but for peace of mind
