Here is what I ordered for the GTI:
ECS Timing chain kit
ECS silver billet crackpipe and thermostat housing kit
ECS tuning silicon hose kit
Green temp sensor
VSS sensor
Rever backup light switch
Upper and lower coolant hard lines
Spark plugs
Serpentine belt
Vacuum hose, Oil filter, fuel filter, fluids ext.
The car was due for general maintenance all around, so i pulled the trigger and got as much as I could afford.
Here is the car before going under the knife...
Removed the transmission, and pulled the front clip. Not bad for an one day...
Intake manifold out, and upper and lower timing chain covers out.
Upon closer inspection, the upper guide rail had cracked in half and was causing the slapping noise. Also the upper tensioner bolt was jammed and look sort of black, or burnt. Cogs looked okay, so I went ahead and started replacing the chains. It took a little time, but wasn't too bad.
Timing chain install finished and covers all sealed up. Definitely took the time to clean all the mating surfaces so i would ensure no leaks.
I then moved on to the crackpipe install. Unfortunately I don't have a lot of picture of the install. My phone had died. There were no leaks from the crackpipe itself, but the lowest part of the thermostat housing was leaking. The hardest part imo of this install is the removal of the smog pump. OMG it was such a pain. The whole install was pretty easy due to the front end being off and the trans out. It Gave you a lot of room to view down the side of the motor (driver side) and inspect the coolant openings and seals.
I reinstalled the crackpipe with a little rtv sealant on the o rings to ensure no leaks.
Crack pipe out
With the chains and pipe installed, it was time to put the transmission back in place. Reinstalled the flywheel and clutch ( both had barely 3000 miles on them, so i cleaned and reinstalled)
The trans is now installed and wired up, just waiting of my coolant hoses, oil pan, and a cv output flange bolt for the transmission, It was stripped when i had to remove it, luckily it came out with a little work. So far Im pretty satisfied with my work. I have been working on cars since high school, but never on anything european. Definitely was intimidated at first, but this repair has given me the confidence to repair anything on this car. Hopefully if should be back driving next week after a 11 month hiatus. Crossing my fingers hoping I didn't mess up. If I pull this off, It will be the greatest achievement of my life! lol
