I'd rather not swap it into either of my Caddy's, and I've been thinking of a couple of ideas, but wanted to see what is out there for everyone else's ideas. I'd really like to have a hatch of some sort, MKII and up...GTI, Golf etc. There's no transmission either, and it needs alternator, flywheel/clutch etc. as well, so it'll need some donor engine accessory parts too.
What do you guys have out there for possible donors? Anything newer out there with a blown up motor?
Parts needed:
[*]VR6 MKIII engine mounts, rear and right side - NEED
[*]24v ECU/engine management - NEED
[*]VR6 exhaust - NEED
[*]Corrado G60 or B3 Passat Speedo Cable (mechanical cable) - NEED (maybe)
[*]Passenger side mirror - NEED
[*]Exterior passengers side trim, just in front of door on fender - NEED
[*]Glove box - NEED
[*]Ebrake light module in dash - NEED
If there's something I need to add or change, please chime in.
- Cosmetics:
- Interior mirror trip cap - FOUND
- Driver side door card, handle and window crank - FOUND
- Front H4 headlights, broken drivers side - FIXED
- Passengers side fog light - FIXED
- Hood release cable - FIXED
- Ebrake handle/assembly - FIXED
Motor: - VR6 MKIII Subframe - FOUND
- VR6 downpipe/header w/ O2's if possible - FOUND
Transmission: - VR6 transmission - 02A or 02J, cable clutch - FOUND
- VR6 Shift box and cables for VR6 trans - FOUND
Axles: (wanting to keep 4 lug) - For 02A trans - two options, 90mm or 100mm axles. - FOUND
Steering: - PS lines?
This...
Going into this...
