1992 GTI R32 VR6 project...
Re: 1992 GTI R32 VR6 project...
I have a different transmission for it.
- SweaterVest
- Vehicles: 97' VW GTI VR6
Do you know what tranny you're putting behind the R?
Mikewire wrote:I have a different transmission for it.
Pretty sure mike is using this tranny
Should be an 02A, but I need to confirm numbers. I just got a load of parts from Leifro, and this is one out of a Corrado I believe. And supposedly has a Pelican LSD already installed.
Lots of other parts as well, subframe shift box and linkage, downpipe, axles etc. Waiting on an MKIII gas tank, lines and pump. Pedal assembly and hydro setup from Benno coming as well.
Should be good for now! Looking at engine management options...AEM or MS2.
That DP have my handwriting on it?
I didn't look at it that closely, but I'll be checking for it nowMT-Getto wrote:That DP have my handwriting on it?
from a local guy who has AEM says its really finicky, not sure why.... honestly i would look into running stock management. The comfort of knowing its gonna run all the time out of the box, and scannable at the same time. plus any configuration you can think of can be tuned on stock management. Will also have all the VVT which you cant run as thorough with standalone, basically you can turn the vvt on or off, but not variable as it should be without a ton of work. or so ive read....
Good info!
kompressorgolf wrote:from a local guy who has AEM says its really finicky, not sure why.... honestly i would look into running stock management. The comfort of knowing its gonna run all the time out of the box, and scannable at the same time. plus any configuration you can think of can be tuned on stock management. Will also have all the VVT which you cant run as thorough with standalone, basically you can turn the vvt on or off, but not variable as it should be without a ton of work. or so ive read....
- Leifro
- Vehicles: 80'VrCaddy
83TCQ-85S1
90Corrado-83GTI - Location: H-Town Montana
That man whore trans gender wimp owes me on that $20 bet I lost. Mine was still bigger...YASHA7FOLD wrote:
