I have a VAG-COM in Missoula now.
Discussion regarding the software diagnostic solution
I flash the Touareg's ass all the time!!
Rennwagen1 wrote:I flash the Touareg's ass all the time!!
You go buddy, let those other soccer mom's know what's up.
S406
Post by S406 »
Hey Aeron I need to see whats going on with my carrado. Is it possible to hook her up?
Yeah, no problem. I usually leave the laptop at home, and usually after work wrks best for me. I could do it tonight (tues) or thursday or friday. Let me know what you want to do. you can give me a call at 544-8258, and we can work something out. Bring a sixer of Kokanee or Cold Smoke and we will call it even!
S406
Post by S406 »
Sweet! Will do. I will give you a call, Im waiting on a radiator part so thursday friday maybe. Thanks allot man
Rennwagen1 wrote:Yeah, no problem. I usually leave the laptop at home, and usually after work wrks best for me. I could do it tonight (tues) or thursday or friday. Let me know what you want to do. you can give me a call at 544-8258, and we can work something out. Bring a sixer of Kokanee or Cold Smoke and we will call it even!
Hey, I too would like to hook up. Can I keep my headlights from turning on as soon as the ignition is on and ebrake are let off? My headlights are on all the time and would rather just city lights lit unless I turn my headlight switch on?
Thanks man
Jason
yeah, that is probably possible. Check for the coding on the vortex in the Mk4 forums and see what you find. You may even find other stuff that you want to do to it also.!
G60, I am not too familar with the corrado plugins, does it have the standard OBDII connector under the dash?
Rennwagen1 wrote: G60, I am not too familar with the corrado plugins, does it have the standard OBDII connector under the dash?
No, it has a 2x2 connector under the shift boot, you will need a special adapter to read the codes. Even then you will only get basic codes.
Edit: on the G60's i'm pretty sure the only codes you can pull are the abs codes from that connector. G60's aren't OBD as far as I know.
S406
Post by S406 »
I think its under the hood on the battery side. Im not sure I will find out. With my luck I will be screwed and have to go pay out my ass at Mtn Imports
Guess im wrong! Thanks Roadhog. I need to see what sensors are bad or what has tripped a code or 5.
Ah, I don't have the 2x2 connector, so we maybe screwed in that case. I have the Hex+Can connector.
