VR6 GLI Build
Re: VR6 GLI Build
Well....... Looks like I will be finding a new motor :( Lost oil pressure and got towed home. Dropped the pan and found a piece of thin metal 2 or 3 inches by 1/4 inch and a lot of sparkles. Replaced the pump anyways and still no pressure. :banghead: It was fun while it lasted!
Re: VR6 GLI Build
:eek:
Did you spin a bearing?
Re: VR6 GLI Build
Not sure.... Ill soon find out. Should have it out in the next couple days. I hate coolant.
Re: VR6 GLI Build
MikeWire wrote::eek:
sounds like it
Re: VR6 GLI Build
should have mr. motor on the floor by the end of the day
Re: VR6 GLI Build
Oh crap, that is the suk!!
Re: VR6 GLI Build
Here is the piece I found.
Engine removed..... It no longer looks like this.
Re: VR6 GLI Build
:question: Kinda looks like it could be a rod bearing, but that piece is so small it doesn't look like it. Do you have any excess play in the bottom end, like loose caps or rods? How about the thrust bearing or a piece of crank bearing? If you are lucky maybe you just have a bad crank bearing or it spun just so far to block the oil hole, thus the loss in pressure. Either way you should pull the crank and have it mic'd and check the bearings. That's easy and cheap - no pulling the head or pistons and seals are inexpensive. If it's a crank I bet you could grind it or get a used one in good shape if it's toast. You'll have a good motor when you are done!
Re: VR6 GLI Build
Looks like a rod bearing to me.
Re: VR6 GLI Build
Getting the garage cleaned back up now. I'll dive in and let you guys know what I find. I guess Ill start with removing the crank.
I did a lapse of removing the motor :)
[youtube]http://www.youtube.com/watch?v=bZxJjgvp56Q[/youtube]
