C/R on a 1.8L bored .040 over?
Hi!
I have found a super cheap .040 oversized pistons/rings/pins set for my 84 GTI, and I was just wondering if anyone knew how much the C/R would be affected. I am looking to raise it a bit(not much maybe .5-1.0) and I was wondering if I would need to deck the block, or what? I do not want to lose any compression, for sure, just keep it the same, or maybe increase it a bit. ANyone have any experience with this? I have a few people I can call, but I figured that I would ask you guys first! Thanks!
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Post by ValveFloat »
I'll take a shot at this.
I am making a bunch of assumptions, but here we go:
stock bore: 81mm
Stock stroke: 86.4mm
Cylinder volume: 445219mm^3 or .445 liter.
Bored bore: 82mm (.04" = 1mm)
Stroke: 86.4mm
bored cylinder volume: 456280mm^3 or .456 liter
Stock CR is 8.5:1?
.445L/Combustion Chamber Volume = 8.5
CCV = .445/8.5 = .052L
Bored CR = .456/.052 = 8.7
okay, well you are far too smart for your own good. SO buy that calc, I would actually be raising the C/R fromthe base line by about .2? So then if I were to deah the blocka abit, that would only help it further? Hmmmm I am beginning to think I might get my snorty little 8V going faster than I thought.....
benny_mech
Git on it!
Post by benny_mech »
Hey Aeron,
I fired off an e-mail to you about this, but ValveFloat's math looks good to me. There's a lot of other considerations when decking the block or head to bump compression. Any meaningful bump in CR means you'll be out of spec for machining, and you'll have to do some valve to piston clearance checking.
Thanks for the info and hello from the Big Sky!
Custom VW
Post by Custom VW »
I love it when people read....... correct formula's make a big difference in the world. Valve clearance isn't a big issue on that block, so your GTG there, just don't ever go past 11:1.
My little 2.0L 8v, is currently at 11:1, and down from 11.5:1. at 11.5:1 it was hard to keep it streetable on pump fuel. It's still hard, but seems to be at the limit and stable.
so are you saying that the formula above is correct, or not? ANd how is your 8V on power, I bet it is fun! Running premium fuel in it?
Custom VW
Post by Custom VW »
CR = SV+CCV+HGV+DHV+EDV
CCV+HGV+DHV+EDV
Where CR = compression ratio
CCV = combustion chamber volume
HGV = head gasket volume
DHV = deck height volume
EDV = effective dome volume
SV = swept volume
Custom VW
Post by Custom VW »
