What glow plugs do you use?
DynoJetta
'03 Jetta TDI (RIP)
Post by DynoJetta »
Alright, we need to get some more participation going on in the TDI Section! I know there are some other TDI owners on here!
It seems like I have been going through glow plugs more often than I would like. Every time one of my plugs go out I get a check engine light. I can honestly say my CEL has been on for more of the life of my car then it hasn't. Granted, I have been buying the cheaper Autolite plugs, so that might be the biggest reason.
Anyone have any luck with other glow plugs out there? Let me know what you run, and what kind of luck you've had with them!
Image :D
Dubber
Re: What glow plugs do you use?
Post by Dubber »
I am not sure what type of glow plugs are good - but i know that almost all autolite plugs... are not all that great of quality..
soo.. bump for someone who knows more about diesels =)
Glow plugs - not spark plugs. Diesels don't have spark plugs.
Josh, I think you are the only TDI owner on here, although I know there are a couple of other diesel owners? I don't think they are very active on the forums right now.
Dubber
Post by Dubber »
Where did anyone say spark plugs!?
Dubber wrote:Where did anyone say spark plugs!?
See you Friday Grant :evil:
Dubber
Post by Dubber »
Bring it ON Mike! :finger:
Oh snap! Is it going to be a VW nerd fight? You know when we fight, we all loose.
Back OT!
vrtpassat
Post by vrtpassat »
you need to run oe glow plugs and if they are failing that soon you should have the control modual checked out if it is malfuction then the plugs stay on longer than what is needed for starting.
glow plugs are only supose to run during start up cause of the high compresion with really no ignition system.
compretion, heat, fuel, all that is needed to run a desiel trust me i no it is what i do for a living is work on desiel engins :thumbsup:
busafied05
Vehicles: 03 Jetta TDI
02 Tahoe
05 Suzuki GSX1300r
Post by busafied05 »
I know this an older post but thought I would give my .02. When I first bought my TDI 2 years ago 2 glow plugs went bad right away as well as the harness. I bought a box of NKG plugs at napa on sale, replaced them all and haven't had to replace any since, also I replaced the wire harness as well (not as hard as thought it was going to be).
Does having a tdi in a garage make a difference in glow plug life? I would think starting in below freezing temps would be harder on them than in a nice 50 degree garage.
2003 Jetta TDI (125k)
vrtpassat
Post by vrtpassat »
yes cause they do not have to stay on as long to start :thumbsup:
