To Cap or not to cap
That is the question. I come from the old school ways of running the amp with out a cap. I've seen some set ups with them and with out. Just wanting some opinions.
1991 VW Fox
1989 Jetta GL (long gone)
Real racers do it in the dirt
- Spoolin!
- Vehicles: subi's and vdubs
Re: To Cap or not to cap
well there are a lot of variables here.
how do you listen to your tunes? rock out for multiple songs before you give the sub a break?
how many amp alt?
how big of battery?
how much power can the amp dish out?
most caps help (in the ideal situation), but only to an extent. they will hold a charge, and take SOME strain off the alt and main battery, but only for seconds (around 30 at most)
The "farad cap" in 99% of most situations are useless, even the big ones (other then JL's 1000 farad cap) they have even been proven to drop the average voltage going into the amp, thus resulting in a loss of SPL and SQ.
Most people use caps to help with head light dimming while night driving. but the technology is old and out dated. If you really feel the need to get some extra battery help then just get a Kinetik (<- ebay search it) and call it a day, they are a little pricey but WELL WORTH IT. I personally would recommend you simply replace your current regular old car battery with a kinetik, you will notice a HUGE improvement with your power drain issues.
hope this helps
PS: i run without a cap, or a kinetik. BUT i relocated my regular under hood battery to the back as close to the amplifier as possible, and i run a 90a alternator. i notice my headlights dim, but i never drop below 13v.
how many amp alt?
how big of battery?
hope this helps
I have used them for years, and never had a problem with They are mainly used if you have a mono(sub) amp. 2 or 4ch amps don't neet them as much, although they can help. A good rule of thumb is 1 farad per 1000w of sub amp output. I personally run a Kenwood Excleon X401F and an X501M that is pushing around 1200 watts to the subs, and I have never noticed a problem, and I have had my cap for 11 years. Seems to work fine to me!
Thanks for the info. the amp I got its a small one. the head unit puts out 500w itself. but not enuff to really push my subs.
1991 VW Fox
in my old system i rocked a Rockford Fosgate 50 Farad Capacitor, was about as big as my amp. and that was only on a one Amplifier system hooked to a single JL Audio 12W7. a bit excessive, absolutely! was on close-out and i was in the mood
Now to hijack my own thread. Aeron I need some wiring help. Can't find a switched fuse to run my deck and don't have a wiring diagram to assist in this.
She's a 91 VW Fox.
She's a 91 VW Fox.
1991 VW Fox
Umm, why isn't there one in the stereo hole in the dash? If there is not, the first thing I check is cig lighter, cause it is ususally near the stereo. If that is constant 12V and does not turn off with the key, then I usually go right to the steering column. Just find where the harness comes out of the column shroud, and start check the smaller guage(larger) wires. The constant in VWs is usually red, but I am not sure what the switched accessory wire would be. Use a multi meter or a test light.
Unfortunately my multimeter got eaten by a mouse infestin my muck room.. will try just runnin my fuses.
1991 VW Fox
